Hello, has anyone encountered such an issue before? When printing, from time to time, the platform starts shaking strongly. What could be the problem?
“Wow, this seems a bit complicated for me. I’m thinking, could it be because it’s weakening due to the temperature? I just started printing with PLA at a bed temperature of 70 degrees, and there are no such hiccups. But when I print with ABS at 96 degrees, after a while it starts to shake. Am I imagining this?”
There might be all kind of reasons why this happens - I do not think it is strictly connected to temperature.
Do not be afraid of doing the adjustment - it is not really complicated. Make sure you own callipers, otherwise you’ll have difficulties to take the distance measure. Callipers are a useful tool anyhow, so not wasted money. The only “be careful” step in the procedure is when you re-insert the slider - do not damage the end switch.
The alternative is getting new linear rails - but that’s a rather expensive solution to something that with less than an hour of work can be fixed.
EDIT: I just realized that they changed the How-To guide online! It seems that the T/F-Modules have a slightly different procedure! I found this for the “old” procedure:
