The laser cut/engraved nameplates didn’t come out popping as much as I had liked. One for hubitat another for Flic buttons.
I’m glad I measured with calipers before cutting the plates. The height came out a full .2 mm less than speced in Fusion360 from layer height tolerances I suspect. Even then cutting down to .1 less than physical measurement it was a real tight fit. But snug is good. Coated them with vegetable oil to slide in better, but still had to hammer in basically.
And after all that my predesign measurements were off and the thing was a couple millimeters too high to fit on the shelf at the bottom of the network cabinet. Oh well, I def have room to shave some off and reprint, or lower the shelf another slot.
