Machine stopped reading Laser NC files from a USB drive today and also from Luban file transfers. It did read the Firmware file update and uploaded and updated the machine from the USB drive.
Looks like similar issues reported. Any solutions? Thanks
Is your device storage full?
Try deleting gcode and NC files.
Hope this helps!
Also make sure that the laser module is attached and recognized; the machine will only display files appropriate for the toolhead currently attached.
Which is annoying. Should be a way to see ALL files, and SELECT ALL files function.
Thanks, you pinpointed the problem.
The cable to the Laser head wasn’t attached securely.
