I have a SVG file that renders fine in Inkscape, Vectornator, Graphics Converter, but when I upload it Luban, it is rendered with objects missing. Tried grouping, saving in different programs, filling. Nothing works.
I am guessing that the SVG includes all the lines and the white center part is a separate circle “on top” (except for some specific lines at 0, 45 and 90 degrees). So the order of the layers is important. That won’t work in Luban. You’ll have to really cut of the lines in the original figure. (which you can do in inkscape for example)
The following may work: Mark all objects in Inkscape (Ctrl+A) and use “Convert Object to Path” and save SVG again. Luban is known for not interpreting all objects perfectly, but usually pathes work just fine. If not, I’d second what brvdboss suggested.
I am converting from png, jpeg, gif images to SVG at the following site.
I have never had any errors with this conversion.
this will result in a loss of the vector aspect of the file. I need the higher precision. But thanks.
