Luban Laser - dimensions are not correct
I’m trying to laser a grafik - made in CorelDraw.
A “very complex design” - a circle with 100m diameter.
  1. Export it to svg and load it in Luban -> circle no about 26mm diameter.
  2. Export it to jpg and load it into Luban -> circle now about 145mm diameter.
    (Luban 3.9)
What should I do to get the grafics from CorelDraw in the right size to Luban ?
regards
K.D.
I found that the problem is Luban 3.9 !!
In the 3.8 version the size is how it should be.
"This is the new version of Luban.
** What is new ?**
*** New bugs."***
I like the feature of creating simple shapes in Luban quickly but I also noticed the size changes between Edit and Process!
Creating three circles in Edit mode:
In Process mode you see the first circle has ‘grown’:
As far as I found it is only the first shape that changes size: So delete the first shape in the session and make a second one.
