Lucas
March 24, 2023, 5:37pm
1
I’m doing laser cutting only, Snapmaker 2.0 A350T, connected via USB cable.
Camera capture doesn’t work, option is just greyed out. This has worked but cannot remember when.
Since 4.7 Luban doesn’t auto detect the type of Snapmaker I have (2.0 350T). Also updated firmware to latest, no difference.
Cannot start a job in Workspace. The head goes to work origin and stayes there. Same file via flashdrive works fine.
Transfering a file to the device over USB doesn’t work, has worked over Wifi but since I use the cable this option is greyed out.
Importing a SVG file made with Illustrator in a certain dimension imports in Luban about 3 times bigger.
Any suggestions are appreciated.
sdj544
March 24, 2023, 11:58pm
2
Camera capture only works over wifi.
It’s a physical limitation of SM hardware.
Lucas
March 25, 2023, 6:53am
3
Ok thanks. So how to get the wifi working?
My Snapmaker won’t even respond to a ping from the network, but has internet itself.
As I said before, lack of professional software management is the main problem here. Old problems reappear!
Lucas
March 26, 2023, 6:30pm
5
I guess so, so what is the solution? How do you deal with it?
Its probably your router which blocks the connection in your wifi.
I dont have such a behaviour in my network with latest firm (1.15.21) and software (4.7 not sure about the number).
Restarting the router is a good point to start.
Lucas
March 26, 2023, 6:49pm
7
Could be, but why has it worked before? Can you ping to the snapmaker? Or does the snapmaker block pings?
Dont know sry, my snapmaker appears in Luban for connection.
I could imagine a block of snapmaker because of the half android interface..
But you could simply roll back the luban version.
Jan 19, 2023: v4.5.1
Brief changelog:
Note:
Added support for macOS with M1 chip
Remove support for Windows ia32
Remove support for macOS 10 (Catalina, Mojave, High Sierra), please upgrade to at least macOS 11
Bug fixes:
Fix: Fix printer auto connect bug that causes bed hitting
Fix: Fix SVG distort issue
Fix: Fix linux executable by adding --no-sandbox option
Fix: Remove SM 2.0 prepend G-code settings
Fix: Fix broken anchors on parameter table
Fix: Fix wrong display of toolhead in Setting…
Remove the hobbyist programmer!
