Luban functions suggestions
I’ve been using the laser for a few weeks and I’ve notice that everything i send to luban is way to dark to work with.
could we get a pass trough function that would enable the user to use the file as is and bypass the luban process, i process my files on gimp and other program and i don’t need to add more processes on top of it.
also a function to be able to engrave and cut on the same g code would be a worth wile tool.
If you already have a program which generates G-Code you can directly load the G-Code file in the “Workspace” tab. Then AFAIR it gets printed as is.
If xou only use GIMP and other image programs though you probably end up with a bitmap based image file. Then you will always need another tool to convert it to G-Code the machine understands.
See A250 laser engrave & cut : Basically it’s possible by adding multiple objects to Luban and then setting the Laser settings separately for each object.
