Just wondering is it possible to use the laser to engrave & cut in the same file/image?
For example, I’d like to engrave an image, but after the engraving is done, I also want to cut out the image, so that I can remove excessive boarder.
I guess I could do two runs:
- prep the engraving file and engrave first.
- prep the cutting file (only outline the boarder of the image) then cut the image.
Is there any way to combine the above two runs into one run?
Edit: I came across a vid in the Snapmaker youtube channel, and it showed that it’s possible to do engrave & cut at the same time, any tips on how to do that?
Thanks!
Jay
