Hey there,
I have a cribbage board I designed in Tinkercad that I want to CNC. The model is basically a cuboid with lines and characters engraved in it. The lines and characters are 3 mm deep.
I want the CNC to cut just the lines and characters you see in the picture. The material is already cut to shape. I plan to fill in the cuts with resin afterwards and then manually drill the holes with a drill press. When I make a toolpath in Luban, it is cutting what I want it to cut but the issue is the depth. I put 3 in ‘Target Depth’ and .5 in ‘Stepdown’. In my mind this means it should do 6 passes lowering by .5 mm each pass. But it is only doing two or three passes, not reaching near it’s target depth. I’ve tried messing with the target depth and stepdown a little but it still won’t cut deep enough.
Any ideas? I appreciate any help.
(I know Luban is super limited and I should learn F360. I tried for a bit but got super frustrated with it as I couldn’t get it to do what I want.)
