Working on a project - a wooden watch box - that I wanted to carve a design into. But I encountered what I think is a strange behavior from Luban, so I am hoping someone can help explain why I’m seeing what I’m seeing.
The wood I am using is maple. The Luban version I am running is 4.13.1-beta.1. The CNC bit I’m using is a V-Bit.
My process is as follows:
- Create an STL file (using Sketchup) that is text surrounded by a rectangular box. I want the text to be level with the surface of the maple and the area inside the rectangle to be lower than the surface level approximately 1/16". See picture
- I imported the STL file into Luban’s CNC function and got the design oriented correctly.
- Created a toolpath with a target depth of 2mm (pretty close to 1/16"). Here are the settings:
- Ran the job, but got little in the way of depth carved from the wood. Could barely see any material removed.
- Ended up creating several versions of the same toolpath (using the same STL file) but increased the target depth from 2mm to 3mm, then to 4mm, then to 8mm and finally to 12mm (which is almost 1/2"!). Increasing the target depth did generate closer results to what I was looking for but the target depth set didn’t correspond at all with the actual depth cut into the wood. The run with a target depth of 12mm created a recess around the text, but it was only about 1.5mm. I ran all these tests on the same piece of wood side by side - see the picture below. The numbers above each run are the settings for the target depth.
So I am confused by the results I am seeing. About 9 months ago I created a similar carving, but did not have the same problem that I am seeing now. Not sure if I am doing something different (i.e. wrong), or whether Luban is operating differently now.
I would appreciate it if someone could explain why I’m seeing this strange result.
Thanks,
Rick
