Hi everybody,
have run another print using Luban 4.9.1 on a J1 today and the printer finished successfully. Unfortunately, Luban itself did not… Job Status stuck at 99% - even having the bed cooled down to 35°C…
Any idea by when Luban will show 100%?
Thanks in advance!
So did you pause it? Because the screen shows you paused it, since pausing isn’t on the screen and has been replaced with the green Run arrow.
Actually no, I did not pause the print (and did not press any other button) - it just stopped showing this “setup”…
Fun fact: it’s possible to edit the file name - or - to close the workspace window, slice another file and start another print…
So not really sure what is happening there in the background…
Maybe? Even when I shut down Luban completely and come back into the Workspace area it still holds the last file completed, if you do that does it change to 100%? I’m wondering if the system dropped the last positional data request from Luban or refused to post it, thats all
hmm… okay, will give a try next time
Will let you know
Good morning everybody
Just started LUBAN and have the “basic view” when selecting the workspace (as promised in my last post
Connecting to the J1 shows the following on LUBAN:
and this is what i see on the printer itself (currently running a 3h print…):
Looks like something strange is happening here - or the sync between LUBAN and the J1 has not been implemented/tested properly…
Any ideas?
