Now that Luban doesn’t scale dxf files I wanted to switch back to eliminate the step of converting them to SVGs for the cnc or laser. But when I try to open the attached file I get an error telling me to use a supported file format.
The file is a dxf which should be supported? I’m exporting from Vectorworks, so wondering if there’s an issue with the export? Illustrator recognizes and opens it fine. Any thoughts/advice would be appreciated. Thank you - FAS
PS OK won’t let me attach the dxf file, but it is a .dxf
