Luban 4.10.1 Air compressor function button for 10W laser
It would be nice if there was also an option for the 10W laser (see picture) to activate the air compressor that comes with the 40W laser.
It’s certainly not such a complicated programming task!
As I have retrofitted an Air Assistant to the 10W Laser, I would like to activate the Air Compressor directly via Luban and not in the Marlin code!!!
Hello, I have also retrofitted the 10W laser with the air assist mod. I tried using M8/M9 to turn on/off the pump but those commands do not seem to work unless you have the 40W laser attached.
What M code values are you using to turn the pump on/off when it is attached to the headed bed port on the A350?
That’s why I asked the development team whether the option could also be enabled for the 10W laser or activated in the program. So not only for the 40W laser but also for the 10W laser to add the option.
I also like this idea and vote for its inclusion in a future software/firmware update.
In the meantime, I have purchased a separate 24VDC power supply, added Anderson Powerpole adapters to the cable and can turn the pump on/off manually when the 10W module is attached.
Would still like the option in software.
I second this request. It would be very useful to have that command enabled for the 10W Module
Hi. I just got a replacement power assist module form SM. I understand the Air Assist Module have three pins. Can you walk me through how you used the adaptor? Which one is each to connect to the AC 24V cables? Thank you. Tris.
