I just got a new A350 and the first thing I mounted was the Laser module. I am wondering about a “feature” I encountered when accessing the settings for the laser module (either Luban or the touch display) If I access the laser Power setting the fan in the laser module turns on and stays on. Even if I don’t change anything and return to the main screen. Is this normal behavior?
Did you turn on the laser? Or are you saying you just adjusted the power without turning it on.
On mine it generally stays on for a while after it’s been turned on but eventually turns off. I think this is a normal part of the cooling down process. Really haven’t paid that much attention to it.
