Looking for 0.25mm Nozzle Profile for IdeaMaker
I am looking for a 0.25mm Nozzle profile for Ideamaker, Cura, or Prusa
(IdeaMaker preferred, 0.20 or other close nozzles will work)
I want to use my Original Snapmaker for some highly detailed small game pieces (Miniatures) and a small nozzle would mean better details. Since most of these will be TINY, the print times will be proportional and acceptable…
Just need a starting point on Print speed and a few of the other items. I have the nozzle installed but am have a bear of a time getting the first layer to stick… not sure if it is speed, temperature, or what.
Currently running 210/60degC and 10mm/s base rate, Z-zero is set to 0.10mm with a thickness gauge, and my first layer is set to .08 for a total thickness of 0.18mm or ~72% of my Nozzle diameter…
I would suggest to print a higher 1st layer to get better adhesion, like 0,16mm. The most miniatures use a socket, so this would not effect your model that much.
The other settings seem fine to me, i would not print the model faster than 40mm/s, which would really fast.- 20mm/s is a good starting point.
1st layer speed depends on the layer thickness, the thinner you want it the slower i would try.
But one has to be said, i never printed that small first layers really well.- This depends on your bed calibration.
