Linear Module Ribbon Cable
Does anyone know if the main cable for the Linear Module is removeable? It appears that it should be able to slide forward toward the motor to be removed but pushing and prodding has little or no effect.
Thanks if anyone knows.
It does not. It molded into the rubber piece.
Ok thanks. I was hoping that rubber piece would slide out but doesn’t seem to be the case.
