Hi folks,
I first thought that Snapmaker messed up the most recent firmware, but turns out I was unfair - it was Lightburn, and after all: My stupidity (no surprise here!). My problem was that I wanted to laser something with the rotary module, and always at start the laser moved up and out of focus. It was actually caused by me enabling this setting:
I just enabled it because I might later play around with it, but I should have thought a bit about the implications. The Z-height is calculated by
- The material thickness PLUS
- The support thickness PLUS
- Any Z offset given in the Job.
Turns out the default for support was set to 10mm:
And that caused the laser to move out of focus by virtue of a Z-move up by 10 mm via GCode…
So, better think things through before switching on settings on a whim… stupid me
