Layers not sticking after the helper layer is put down. It keeps sticking to the extruder instead of sticking to the model I am trying to print. Anything I need to do, or what am I doing wrong.
Clean your build plate with soap and warm water or isopropyl alcohol.
Let it preheat and print on a dry, clean and degreased bed.
Try to lower your live z-offset on the touchscreen till your first layer fits the correct squish.
Maybe lowering the first layer speed would help as well.
Here is a pic as example:
He doesn’t seem to have a problem with the first layer, though he hasn’t described the problem very well.
Yeah sorry the first layer is fine, its when it goes to fill in the rest from there.
Clean your bed or try to increase bed temp.
What material you print on which sheet with which settings?
Clarification, photo or video could help.
