It is very strange to us as well.
Use the command
M1010to check if the Hall-effect switch is triggered when you close the door.- S0: disable door event
- S1: enable door event
Please connect the machine with your PC via the provided USB cable.
Launch Snapmaker Luban
Select the correct serial port
Input the command in the console
We doubt the Hall-effect is faulty.
- As for the 3D printing module, you can control the gear via the touchscreen when the enclosure doors are close.
