Laser just cut a short line during camera paper test
Before it also stopped on a 409 error during a job yesterday.
I cant click continue on the touchscreen when it says put laser googles on.
And, as said, laser just cut a short line during camera paper test.
Please if anyone know what this might be, post you knowledge.
I can add that when trying a job from luban it seems to go and start but then just raises itself up and doesnt do anything. Even though the job is still running.
Check your enclosure door state and it’s magnets:
https://wiki.snapmaker.com/en/Snapmaker_2/troubleshooting/door_detection_error
Is it a 20W or 40W laser?
The 20 and 40w don’t have cameras.
I had that issue (Artisan, 10W laser module) when I tried to have a really tight laser pattern with tiny shapes that were apparently interpretated wrong. Luban created a gcode that didnt have any commands to turn on the laser or move the machine. So it kinda ran trough the file within a second and then didn’t show a completed job. Perhaps it would be helpful to share what you were trying to cut or an example file and settings where this occured to you.
I also figured out that sometimes Luban halts after the auto-thickness detection without any errors but without proceeding, for those situations a manual thickness entry made the job go for me.
Sounds like it’s the built-in calibration sequence.
I was replying to this post :wink:
Thanks everyone for your help. It turned out to be a machine malfunction issue and Snapmaker have sent me a replacement 10W laser.
