We have been using the 10W Laser for almost a year. We cut 0.030 thick Polypropylene parts. Recently the laser is not cutting as well and the edges are rough and we have to force pop parts out.
Material is 0.75mm thick, Speed 360 , Power 45 to 50%
It is sounding like some sort of focus issue, but it may be related to the enclosure if you have it. They have beefed up the code for checking the doors are closed, and it seems to go a little haywire sometimes.
I recently tried to cut some 3mm acrylic using a file that I’ve used before, and it just didn’t cut all the way through. I also thought it was something to do with the lens etc and tried to clean it (couldn’t see anything there) but still had the problem. I did the magnet trick on the door detection and it went back to normal.
Not saying it is the solution for yours, but it certainly fixed my problem.
Perhaps re-run the autofocus calibration procedure with the target that came with the laser? Or are you doing this in regular intervals anyhow? If you cleaned everything, my bet would be on focus also… Or the raw material you use slightly changed and you need to increase power a bit? All just guesswork…
The issue I had was that the laser was not at full power but neither was it at the very low power that you get when running boundaries etc. It was as if the door detection was intermittent, resulting in a PWM style modulation. The laser was actually cutting, but where it would normally do the 3mm acrylic in one pass, it was less than halfway through. As soon as I put the magnets in place, it went back to cutting full depth (no other changes). So I don’t think it is just a case of “no door detect, no full power”.
Even while moving it around to set work origin etc I noticed I could get a variation in laser brightness by jiggling the door slightly.
Put it this way - if you have some little magnets lying around, its a really fast test.
