Hi all,
I wanted to cut a 12inx12in 2.5mm thick plywood sheet on my new Snapmaker 2.0 A350, using the parameters given by this guide:
Which were 1500mm/s Jog Speed, 120mm/min work speed,
Multipass 3x -0.5mm with fixed power @100%
This should take about 7 years to complete, according to the header:
;Header Start
;header_type: laser
;renderMethod: line
;file_total_lines: 110332
;estimated_time(s): 228400048.6159541
;max_x(mm): 139.86040649414062
;max_y(mm): 140.41
;max_z(mm): 0
;min_x(mm): -140.36
;min_y(mm): -139.92554443359376
;min_z(mm): 0
;work_speed(mm/minute): 120
;jog_speed(mm/minute): 1500
;power(%): 100
;Header End
I then tried using the parameters from this thread: Laser cutting plywood
Which were 3000mm/s Jog Speed, 300mm/min work speed,
Multipass 4x -0.25mm with fixed power @100%
this job would take about 16-17 days to complete.
;Header Start
;header_type: laser
;renderMethod: line
;file_total_lines: 147092
;estimated_time(s): 1443979828.6039941
;max_y(mm): 140.41
;max_z(mm): 0
;min_x(mm): -140.36
;min_z(mm): 0
;work_speed(mm/minute): 300
;jog_speed(mm/minute): 3000
;power(%): 100
;Header End
Since the part had some fine features, I wanted to complete it using laser cutting to avoid the limitation of tool diameters and such that a CNC machining would incur. As long as it is cut, I do not mind burnt edges since these will be hidden by 3D printed parts by design
Does anyone have some tips and tricks for me?
I’ll be awaiting your answers!
PS: I cannot post a pic of the part since I’m a new user ^^"
Thanks for the tip!
