Is automatic level compensation working properly?
You can choose arbitrary grid sizes up to 11x11 if you perform the calibration via a laptop terminal.
If you want to compile your own firmware you may be able to use larger than 11x11 as it’s a firmware constant GRID_MAX_NUM that can be changed. There will be a limit at some point, I don’t know if it’s actually 11, I suspect it can be larger.
