Initial setup failed
Hi, I just started the initial calibration process, but the print module misses points 1, 2, 3 it ends up further than the bed, as a result all the other poinst are wrong too. Is there a possibitlity to solve this? Thanks! Greetings from the Netherlands.
Post pics.
Make sure your y axis are properly lined up in the slots. (not too far forward or back)
Also the sensor is not in the same place as the nozzle. It’s to the right.
Hi S, thank you for your help, I’m feeling really dumb that I didn’t notice earlier that I made a mistake, you we’re so right. :laughing: Now it’s better, but the nozzle is still slightly off centre. Can I change that? Thanks again! Loes
Hey @Loes57, as sdj544 wrote, the sensor is off the nozzle.- There is no need to change the center position of the nozzle, because you calibrate with the sensor.
Ok, many thanks, printing now and it seems to be alright! :-). Grtz, Loes
