Inconsistent behavior between machines when wifi connection to Luban lost
This has been driving me crazy ever since I got more than one Snapmaker.
I have three Snapmaker A350Ts, two were refurbs. All three machines are running the latest firmware 1.20.3-20240703. At least when I check for updates it says it’s the latest firmware.
My current workflow is to prepare and slice a print in Orca and send it to Luban to print wirelessly (very much looking forward to being able to send print jobs from Orca directly).
The frustraiting thing is when the connection to Luban is lost, two of the machines switch to the screen where I can control the print job (same as if I started the job on the machine itself).
However, on one machine when I disconnect I get the ““Lost connection…Stop” message.
I can not figure out what setting changes this behavior and whether it’s in Luban or on the machine itself. Obviously I prefer the former behavior but overall the irksome part is that these otherwise identical machines behave differently.
Any ideas how I can get this one machine to behave like the others?
Update the firmware with a usb stick or send the .bin over WiFi to the device and start the update like starting a print.
Obviously the reported firmware is not successfully installed..
It never would have occurred to me that the firmware menu would lie to me. :smiley: Forcing another upgrade using USB seems to have done the trick.
Thanks!
