HI,
I tried replace the filament runout sensor of the Dual Extrusion Module, but after it that module doesn’t use any more. My printer shows the error code
I don’t understand where is failed.
HI,
Did you proper seat the plug of the lifting motor?
Dont know what would happen if the t-nut is false placed…
I solved that problem, but I have had other problem. Nozzle R is not loaded. How ever Nozzle is loaded manual.
Snapmaker Artisan
Problem: When printing with PA-6GF NYLON, a filament runout error occurred several times (erroneously).
When I want to load it again, it only heats the head to 210°c, so the filament doesn’t go through the nozzle.
After I press continue printing, it starts heating the nozzle to 295°C.
But until then, the filament will be filed away.
Workaround → Filament sensor switched OFF.
Solution → Firmware update?
