Hi all,
I got my Artisan, my first 3D printer, a week ago. My first real project is done: an insulated lunch box with plug-in modules, about 20 parts, printed in two colors.
My focus is entirely on what the part should do and how it should look. I didn’t model a single part myself, and I didn’t touch Luban.
- Design: I describe what I want to Claude (an AI assistant): dimensions, measurements of the parts it has to fit around, materials, and so on. Claude builds the complete parametric model directly in Fusion 360 through Fusion’s AI connection (MCP). It also checks clearances and collisions itself.
- My part: I decide on the design and print test pieces to check fit and function. Then I report back, e.g. “dovetail has a bit of play” or “inner shell 10 mm too long”. Claude adjusts the parameters.
- Printing: Claude stores the print settings in the Fusion model: which job, which extruder, orientation, and per-part options like supports or 100 % infill. Its scripts then export the parts, arrange the bed, slice with Luban’s own slicer engine and upload the finished G-code to the Artisan over Wi-Fi. The touchscreen shows the preview as usual, and I start every print myself.
Highlights
- No manual settings at all: no importing, splitting, assigning extruders, rotating, arranging the bed or picking profiles. Claude sets all of it per part, and it’s stored in the model.
- Fully parametric: a test print came out 10 mm too long, and Claude fixed it from my measurements by changing parameters.
- Collision checks after every change caught real errors before printing (a seal bead hitting the lid, a 0.04 mm wall, a misplaced screw hole).
- Only 6 print jobs: Claude groups all parts that use the same two filaments (left and right nozzle) onto one 400 × 400 bed, with the prime tower placed in a free spot. Long overnight jobs are fine, so the main box and a module print together in one 17 h job, while the lids go into a separate job because they don’t fit on the bed as well. Test pieces go into a short first job, and every job is checked before upload (bed position, temperatures, tool changes, supports).
- 19 % faster: visible lines slow, hidden lines fast (63 h → 51 h).
- Changes are quick: only the affected jobs are regenerated and re-uploaded, and old versions are archived.
Is anyone else working like this?
