Hm, a quick test seems it’s working “as intended” which is nerfed. I’m on the latest 1.18.1;
They removed the toggle to turn off door detection in Luban, however, the option is still available from the enclosure settings;
It also responds properly to the M1010 S0/S1 commands, note the “Enclosure” mode being turned off and on.
Off:
On:
I was able to quickly run a project with the door open after using M1010 S0
HOWEVER
With the door open, it lets the project run, but only at minimal power, despite the door detection being off. So with the latest firmware, you’ll have to either unplug the enclosure fully, or put a magnet on the hall sensor.
EDIT: WOOP Found the solution with a typo! Apparently S10 “opens” the door, and S11 “closes” the door, regardless of the actual state of the door!
Door Open;
Door Closed;
Just flung the door open, sent M1010 S11 via Luban’s console, verified it said door closed with a clean M1010, and ran a project. Full power go! Enjoy your janky workaround and BE SAFE. WEAR GOGGLES, KEEP DOORS CLOSED, ETC. I’m not responsible for any injuries.
EDIT2: M1010 S12 will reset the door status, reading the sensor and setting the flag appropriately.
