My U1 has started leaving a clean horizontal gap around the model at roughly the same height on different prints. Photos attached:
Multicolor cat in a striped sweater: the layers separate in a ring around the neck/shoulders.
Bear in a hoodie: a slit runs right across the back of the hood.
The rest of each print looks fine. The gap seems to show up at a similar Z height no matter which model, color, or toolhead is printing at that point, so I suspect something mechanical rather than the slicer or filament.
Details:
Firmware: [2.0.0]
Snapmaker Orca: [2.4.0 version]
Filament: [Snapmaker/Polymaker]
Layer height: [e.g. 0.16 / 0.2 mm]
Approx. height of the gap: [19mm and 46 from the bed]
What I’ve checked so far:
Purge bucket fully clipped in on both sides (saw the “Gap at same layer height, multiple models, multiple toolhead” thread where that was the cause)
Lowered the bed by hand to look for anything it catches on
Z lead screws cleaned and lubricated
Z belt tension
Has anyone else seen this, or found a fix? Any suggestions are appreciated.
I realise it’s tedious, but the best way to see what’s causing this is to actually watch it. Take a video if you like (but not timelapse) so you can review afterwards. This might not be a Z thing.
It’s pretty amazing that the machine can do this.
How can it possibly print over a gap without the layer collapsing.
This makes me think that the gap is not occurring as the layer is being laid down, but later on.
I think it’s reasonable to say you weren’t watching this as it was happening otherwise you would have terminated the print pretty soon after.
Which reinforces the suggestion of either watching it or recording a video.
I suggest the whole model is progressively sagging, to the point where a particular layer doesn’t really bond. It then carries on printing at the correct levels, enough so that the next few layers become self supporting. Meanwhile the model continues to sag below the non bonded layer.
How? You must be joking. There is no way it could (as you put it) “sag” unless the chamber temperature was excessive, and then you would see the melting in the surface detail.
The OP has not stated what filament is being used, I presume PLA. There is nothing at those splits which would seem to promote warping, except that I have had a little trouble with the side fan kicking in and blowing a draft across at active print level. However, this doesn’t look like warping.
The “cat” looks thick enough walled, but what about the Paddington? Is it only a thin skin?
It doesn’t look like there has been a layer shift, but who knows.
Interrupted filament feed due to a tangle on the spool? But why would it carry on again afterwards. Ditto nozzle clog. And why repeatably?
If the defects occur at exactly the same layer height every time (for a specific print file), it’s a G-Code error.
To establish a good assessment: are the problematic layers at EXACTLY the same spot? As in, when you measure this with calipers, does it start at EXACTLY the same spot?
This is quite relevant to the possibility of fixes.
Missing steps is a fair point of Zoe.
I assume your filament path is fed correctly and there is no counterforce at any point of the print? (could you pull or extrude filament easily at the affected height?)
Please zip and upload the G-Code file so we can have a look at it (if it won’t upload as an attachment to the post, use a file sharing website or Dropbox/Google Drive/OneDrive whatever).
