I recently replaced the hot end on my Snapmaker 2.0 A350, and now it’s not heating properly. The display shows 0 C, and the end doesn’t heat up at all. The printer module itself does seem to be recognized though. Any idea what could be wrong here?
Also, I was examining some of the other electronics while I had it apart, which connections should I be checking?
Thanks for the help! Sorry for the delayed response, but I have some other information:
the load/unload buttons that are highlighted on the touchscreen in the first screenshot are greyed out. We can adjust the temperature by sliding the temperature bit left to right but it doesn’t change the 0
checked the thermistor and tried changing back to the other nozzle; neither seems to work. the replacement head thermistor doesn’t want to stay all the way in though
don’t see anything wrong with cable connector
we tried to get the startup log to confirm it is correctly detecting the module but the console just says
