Heated bed temperature drop after first layers
The temperature of my heated bed drops from 70°C to 50°C after the first couple of layers. Anyone having problems with this. I think this it the cause of my prints warping in the first cm of the print.
Can i disable the temperature drop?
That would likely be an issue with the slicing. What slicer are you using?
Hi Arne,
This is no problem or bug. It is a setting in your advanced parameters for material. :raising_hand_man:t3:
