After I installed the firmware v2.3.5 I have been been unable to connect to the internet.
I know the only reason is to check for firmware updates, and that is my concern.
This happened with the v2.3.5 update, that may have been corrupt or incompletely installed as it failed to print the vibration compensation tower when calibrating. That said it does print and I am able to send files by WIFI to the printer.
Should I try the update again from USB?
EDIT - tried the local update and still no internet connection. BTW I have rebooted the router, because I’ve had trouble in the past with smart plugs losing connection for whatever reason and reseting the router has always solved that.
