Hello folks,
Looking for a bit of guidance with something.
it’s something screwy with the Slice as the supports themselves are clean.
The print quality on the 0.6 nozzle is horrid,
Aside from Luban not offering any profile configurations similiar to the 0.4mm nozzle which makes it hard to compare.
I have not run it through another slicer e.g cura / prusa.
Have been wracking my brain trying to work it out.
Filament: e-Sun PLA
Nozzle: 200c
Bed: 60deg
Resolution: 0.18mm layers
Speed: 40mm/s.
Config: Stock Luban 0.6 profile from what I can tell.
Genuine 0.6mm hot end module.
Esteps seem fine
M92
echo: M92 X160.00 Y160.00 Z400.00 B888.89 Current E667.22, BACKUP SINGLE E212.21, BACKUP DUAL E667.22
ok
Measurement comes in near bang on unless I start pulling out a micrometer to get it down to the absoloute.
Filament is dry well dry and had been sitting in the dryer for about 10hrs before~
Can anyone spot what i’ve stuffed up?
I did attempt to drop down to 195, but didn’t want to bring it down further unless I start clogging up.
When completed its pretty much fuzzy all over and it does come off with a bit of effort,
STL Link -
I cannot upload the gcode here as it’s over 8mb.
so here is a G drive link if you wanted to look over it -
What it looks like:
What it’s supposed to look like:
Attached is the JSON file of the current 0.6mm config
Normal Print (0.6).def.json (29.1 KB)
PLS Config, to view change it from JSON to DEF
PLA-ESUN.json (5.6 KB)
Hopefully there is enough info here for some people smarter than me to take a single look and go “aha! it’s that!”
Thanks.
