I am having issues with the Run boundary on my Snapmaker.
As you can see in the images below, I set the size of my stock I will put on the Snapmaker and set the origin point to the middle left.
When I run a boundary check the too path runs along the left edge then across, like it has no idea of the stock size. when I start the job it is all in the correct place.
Has anyone else seen this?
