Full specifications for the fans please
I would like to mod the printer with quieter fans.
Can you please share the full specs(cable length, connector etc. included) for the fans so that I can find spec-to-spec but lower dBA fans? Even better would be an MPN for the fans.
I think the fastest way would be for you to just take it apart. Since you are still going to do it… It is easy though, guides are posted at wiki.
there are specs that I can’t understand just by looking at the fans though. So a datasheet is necessary.
I would also be interested in that. :slightly_smiling_face:
All the fans have model numbers on them. Take that to Google, add “datasheet” and you get a PDF
Fan: 60x60x15mm, 24V 0,20A 2 Pin (Power supply unit)
2 pins only? No PWM? Astonishing.
No PWM only 2 Pins to conect
Power supply cooling fan replacement
Power supply fan is so load, also what is the point with that black cover. It only restricts airflow, let me know if you find a better fan.
