Fixing filament runout always causes XY shift in the print
When the filament runout sensor (or clog sensor) says something is wrong with the filament on my Snapmaker J1 printer, it always is the case. When I fix the issue and load the filament, the printer has already homed the XY axis (and Z probably too). Now when the printer continues with the print, there is always a shift in XY. And this shift always happens. I think this is due to the homing procedure in between. I already have the latest firmware installed.
For that I wish to disable the homing feature in the routine of resolving the filament run out. I understood this is embeded in the M600 g-code command?
I would very much appreciate it if there was a possibility to not home during the routine of fixing the filament runout.
I am a software developer myself. As a last resort I could remove it from the code and recompile the firmware myself if needed. Of course, if there is a more user friendly way to achieve resolving the XY shift I would be more happy with that :smile:.
From the M600 g-code implemetation here, I read the following:
  #if ENABLED(HOME_BEFORE_FILAMENT_CHANGE)
    // If needed, home before parking for filament change
    home_if_needed(true);
  #endif
What ways are there to set HOME_BEFORE_FILAMENT_CHANGE to false?
Thanks.
It would be good if you let it the snapmaker devs know and correct:
Support@snapmaker.com or
Support Ticket Form
Your J1 has a filament runout sensor??? Mine does not, and I’m trying to figure out how to add one.
All J1 models have a runout sensor, it is however very different from what normal runout sensors look like as it uses a extruder gear to drive a rotary encoder therefore it can detect not just filament runout but under extrusion as well.
Its the orange part above the extruder gears in this image:
OK. I found the “Runout Sensor” setting in the Configuration screen, and they are both enabled, but, they don’t seem to do anything. I have had prints merrily continue printing after the filament has run out. Shouldn’t it pause and wait for more filament to be loaded?
Yes it should, seems like you might have to contact Snapmaker support regarding this issue as I have not personally ran into any issues with the sensor on my unit.
Perhaps check your slicer settings as it may be overridden by G-code, check for M412 in your sliced G-codes.
I have not done a thorough investigation, but it appears that the filament runout sensor does not communicate thru the USB-B connector in the back of the printer, which is how I use my printer. [Octoprint running on a Raspberry Pi connected to USB-B]. It seems that some of the J1’s functionality is actually in the front panel, not in the firmware.
