It would be useful, I think, to be able to modify the filament unload temperature on the touchscreen instead of only in the config files. It should help dial in the tip forming more easily if people don’t have perfect tips. It would also help prevent clogs during the unloading process while using 3rd party hotends.
Hi, Thanks for your valuable feedback. I’ll forward this to our firmware development team for further evaluation.
I think a more practical approach might be to allow manual temperature adjustment with a safe range lock, for example limiting the setting to 170°C – 240°C. This would give users more flexibility while still providing a safety net. Prolonged heating above 240°C can accelerate the aging and deformation of the PTFE tube in the U1 hot end.
Oh yeah, good point. A safe range is the way to go, you don’t want to try doing to too low either.
@PolymerAlchemist has already touched on the topic, but I’d like to add my use case. I almost exclusively work with TPU. Soft TPU doesn’t feed properly through the side feeder of the U1. So I thread it manually and load it each time by hand. We print soft TPU (Shore 60A and 82A) on several U1 printers at 218–220 °C. However, manual loading and unloading always heats the nozzle up to 250 °C. We suspect that the soft TPU decomposes at this temperature, partially clogging the nozzle. After that, the filament no longer passes through and is extruded sideways out of the extruder. This has happened to us multiple times.
It would be very helpful if the temperature for loading and unloading could be set via the touchscreen before loading, or if it automatically adopted the printing temperature of the selected filament.
