Fan design enclosure for snapmaker 2.0
Hi guys, this is an enclosure designed for snapmaker 2.0, A250, now it only have a basic frame and 2 doors, I still working on the cooling fan and vacuuming system for CNC part, so far it’s working well to reduce the noise, which distresses me a lot these days.
The main structure is Aluminum profile(4040&2020), other parts can be print out by A250 easily, with some screw bolts and acrylic panels, you can make a nice enclosure by yourself.
I will release the assembly instruction later after I improved the enclosure.
all 3D print parts can be download at
sorry as a new coming user, I can’t upload images, so please go to Thingiverse to see images.
Today I upgrade the cool fan, a 12cm 12V cool fan from a PC case. now it can do the 3D print work fully closed :grin:, previously if it’s fully closed doing the 3D print, it will be full of heat and smell after a while.
Hey guys, I update the ASSEMBLY MANUAL today, hope you like it. enjoy!
Download all 3D print parts and ASSEMBLY MANUALPDF file at Enclosure for Snapmaker 2.0 by wuguigui - Thingiverse
