"Failed to parse file" on Snapmaker
After starting up my A250 after the holidays, I am getting an error on the SM when I try to 3D print an object… “Failed to parse file”. This is only happening with files sent to the SM from Luban. Files sent from Cura parse and print fine. I’ve tried installing Luban again (drag copy install), but that didnt help. Old files in the SM memory print fine. So its definitely an issue with Luban. How do you completely remove Luban for a fresh install (Mac OS)?
Turns out 4.3.2 was a bad release (it’s not even listed in the releases anymore). I don’t think g-code generator ever even worked. So installed 4.4.0 and it works.
