Extruder Hotend Kit clogging constantly
So the hotdead got blocked up and just “printed air” for a bit.
Then i cleaned it all out with specific cleaning kits and got it working again.
but it blocked up soon after, clearned it again then blocked…rinse and repeat.
i finally ended up buying a hot head replacement and it’s been working fine right now. Is this normal it’s only been running for a month this Hothead.
Need more details…
  • Which toolhead did this happen on, the single extruder, or the dual extruder?
  • What filament were you using?
  • What slicer were you using and what were its settings?
Also, basically everything you need to know about hotend clogs on the Snapmaker (not including when the nozzle is too small for certain filaments like wood, fiberglass, carbon fiber, etc.):
The single extruder
BASF Forward AM Ultrafuse PLA Orange | 1.75mm | 750g
Luban, Normal default settings
Ok, yep, the link I posted previously should give you guidance on the clogging. In addition, this next link should give you guidance on how to tune your machine to avoid this and most other issues in the future:
This might be a solution
