In my attempt to eliminate on going error code 13-12 (Calibration Sensor Abnormally Triggered) the filament spools flow was inconstant. To over comes this Frustrating Error on going error. Firstly (1) I removed both spools from the outside mounted case and mounted both inside onto the Z axis, this help to eliminated a build up dust on the spools. Secondly (2) I designed two 3D print filament spool guides, mounted on both Z axis. This worked very well, eliminating the on going error
Hey, that looks awesome. Can you elaborate how you mounted the spools inside the enclosure and share your guides? Would love to move at least one of the spools inside the enclosure as it’s very hard to reach it for me.
Thank you very much
Thank you for sharing your experience and solution! How’s the reliability of this solution after two years usage?
I’d like to add the troubleshooting Wiki for this problem, too: https://wiki.snapmaker.com/en/snapmaker_artisan/troubleshooting/error_code_13-12_13-18
Thanks for showing your interest, yes I still use it and working very well, this has help eliminate the error, adding guidance, stability and smooth direct flow.
Please feel free to use it on wiki.
Kind regards,
James.
