Error code 13-12
While printing this morning the printer beeped a few times than the error message quickly when away.
I could find what the error code means and hoping someone can shine a light to this please.
‘Oops! Something went wrong
Error code 13-12’
Thanks a lot
When I got this message sporadically, I looked it up in the online documentation. That probably means that the height monitoring of the nozzle has detected a deviation. Or the sensor was triggered. I noticed that the filament feed to the spool was kept too short. Then I pulled the hose out further. I haven’t had this message since then.
Thanks. Didn’t know there was an online manual.
I Solved the Problem by turning the nozzle temperature high. I worked at 205 ° C when I also switched 210 ° C, this message no longer came.
