Emergency stop button connection issues
so just received the off button. directions say open up settings on the control panel (phone looking thing) go to firmware update, and then update device. The problem is under settings there is NO firmware update button. So my off button just flashes blue and red and does absolutely nothing because, once again, NO firmware update option on the device. Does anyone have a fix for this?
Download it from the forum and update from a usb drive.
Like sdj said, you have to install the firmware from usb thumb drive.
You do this by start - USB and click the file.
Thank you sdj544 for the information, worked like a charm. Kinda forgot about that usb drive thingy included in the kit! Kinda liking this community a lot!!!
Be careful of the Firmware V1.12.0.
You need to update three tool-heads separately, which means you need update the firmware when every tool-head is mounted, and update the firmware three times.
For laser module, plug it on and the update the firmware.
Switch to the 3DP module, update the firmware once again.
The same to the CNC module.
