What material do you print? Whats your settings? Or your roomtemp did change, do you print with an exclosure? Many questions and no glassball availible
btw do you happen to know if there any pre-Luban processing method to sharpen a scanned -in model . Here is a part of the model Im trying to sharpen. (egyptian) I currently use meshmixer to crop the original model.
Not solving your problem for 3D printing, but it’s a type of detail that is rather hard to achieve.
Now knowing what you try to print, my personal tool of choice would be the CNC (1st choice) or laser (2nd choice) and I wouldn’t have tried doing this with the print head.
As far as room temp: the most important thing is that it’s stable (PLA) So no big changes & draughts. Different story when printing ABS, then you’ll need an enclosure (and ventilation for the fumes).
I suspect some of the curl I’ve had was when I let the inside temp of the enclosure get too warm. In addition to a different remote camera, I need a remote thermometer as well.
