Don't download the Luban 4.1.1 it's dangerous!
Hello guys,
I send this post really disappointed by the release of the 4.1.1 Luban. This version is dangerous for the CNC part of the machine I think, for multiple reasons, I would suggest not downloading it for the moment.
The reasons:
  • Impossible to change the speed of the machine before starting it. Because the velocity is not set immediately but after the current command is finished, it is impossible to start a job safely.
  • Impossible to set the origin on the software with the buttons, you need to disconnect the machine set the zeros and connect it back
  • Impossible to load an external gcode on the workspace. To load it you have to start the job on luban and stop it, but because the stop command is not immediate and need to finish the current command, you can crash really dangerously your bits on the working plate ! Extremely dangerous.
  • The numbers of the grid hide the gcode you are running.
  • The time for the progress of the gcode is not displayed.
These are the first bug I found by using the machine, and some of them were close to injuring me! Even if I’m used to work with this machine. I feel really disappointed by this release and think that Snapmaker should be more careful with the software development instead of rushing the release of new addons to sell more products.
Had to update firmware because of this 4.1.1. release. I am going back to a previous version.
Posted here
This should never have been released.
In Luban 4.1.1. Laser section I found the following so far:
  • No [] show original image option anymore (now shows my SVG’s with white background, which makes hard to align design with camera capture.)
  • Camera capture only shoots one of 9 images and then stops.
Just got the prompt… I’ll hold out for now.
Thanks!
Pug
I just downloaded it. I’m about to 3d print however I noticed that the generated g- code is not showing in the work space after exporting it there. Now I’ll have to press a preview button at the right side menu which then open up a new window. Then what is the point with the huge work space area?
I think I’ll go back as well for now.
I downloaded and installed it before reading this post… After starting it, I found all my custom filament and printer quality settings are gone… Thanks… I think, switching back to an older release won’t bring these back… -.-
Be sure to create an issue on the GitHub repo if these aren’t there already. Snapmaker staff don’t pay any attention to the forums.
Which brings us back to the very beginning of this Forum.Why doesn’t Snapmaker involve themselves here?? That’s the big question, isn’t it…
How do I roll back to my previous edition?
I’m on 4.1.2 and now can’t see my images. WTF
Download an earlier version from this forum to a usb drive.
I’m glad I’m not the only one having issues.
Trying to engrave a logo into a pvc type board, using CNC, the (x/y) axis just goes, doesn’t know that it’s past the workspace and keeps going until it crashes on the end of the machine and keeps hitting the end of the axis.
I suppose I’ll be rolling back as well, this is unfortunate - I hope it didn’t damage the machine. :angry: :frowning_face:
Edit: Snapmaker previous software releases - Releases · Snapmaker/Luban · GitHub
Do you have the correct machine selected? (i.e. A350 when you have a 250…)
This usually happens when someone has the wrong one chosen.
Im using the original, and even after rolling back to the last 3. version, I’m still encountering the machine not knowing where the workspace is. :confused:
Figured it out, I was using the entire workspace when it needed to be centered and smaller, seems like that wouldn’t be a problem usually but :person_shrugging:
Still gonna postpone 4.0 and stick with 3.15
