Luban 4.13.1-beta.2.3.2
I loaded the beta, but it hangs when I select Generate G-Code and Export. I’m trying to use the 1.6 laser.
I see that 27 folks looked at my note, but nobody made a comment. Should I assume that this release is working OK for all of you?!?
Mike
I do not use Luban. Did you try the latest stable (non beta) version?
I would like to, but not sure where to find it?
All releases are found on their github;
The latest stable is 4.13.0
Thanks. Just loaded 4.13.0 and it is working fine.
Stable versions are also downloadable directly from the Snapmaker Support website.
