DIY Rotary Attachment
Did you assemble the correct axis to Y?
Not sure how many difference between 8mm and 20mm axis is but this could be a cause.
Did you print a testcube and it was a square?
I have the older A350 unit. All of the LMs are the same 8mm lead. I may upgrade to the new Modules tho
Hi are you able to share the cut file for the holders that the roller rest in thanks
HI
I’m trying this project out and have a few questions
What laser wattage is being used here?
Anyone using 10 W laser?
Anyone using Lightburn? I’m apprehensive of the laser head running into the bed/assembly when zeroing, I suppose I could cut out that routine.
Also any issues of using the magnetic base that used for printing as a base? I just don’t like the way we have to swap out the various bases for each type of operation printing, CNC and lasering.
Looking forward to your remarks.
Regards
Graeme
