Difference between printers
what is the difference between Snapmaker and other printers? Your thoughts would be appreciated.
Thanks.
Try Google, there are plenty unbiased reviews/comparisons!
Snapmaker 2.0 modular 3-in-1 3D printers are ideal for beginners who are just getting started, hobbyists who prefer more customized options, as well as engineers and designers who want to print large objects or accurate parts with outstanding print quality.
Traditional 3D printers can only 3D print. Your Snapmaker 2.0 is completely different. With interchangeable modules, Snapmaker’s functionality can be changed quickly, just like changing lenses on a camera. Now you can make many kinds of beautiful and artistic creations using laser engraving and cutting.
You can even use Snapmaker 2.0 as a CNC router to create precision 2.5D and 3D objects. It has faster working speed and a much larger workspace than the original model. It is the perfect machine to extend your interest to CNC carving.
Snapmaker 2.0 allows you to print almost anything for your creative projects: from common applications to objects with specific mechanical properties, such as toughness, durability, and flexibility. Snapmaker 2.0 can do it all!
Hey, here is a bit of reading for you: Searching the forum for “worth it”
https://forum.snapmaker.com/search?q=worth%20it
