Difference between Auto-focus and Manual-focus with Snapmaker Laser engraving module
Auto-foucs
  1. If the machine is not yet connected to Wi-Fi, please select Settings in the main menu, tap Wi-Fi and connect to your network.
  1. Before you connect your computer to the machine, make sure both the computer and the machine have connected to the same Wi-Fi. Open Snapmaker Luban and go to Workspace 21.pngConnection → Select Wi-Fi → Click22.png → Select your device → Click Open → Tap Yes on the touchscreen.
  2. Go to Laser G-code Generator23.png and select Load G-code to Workspace to load the generated G-code to Workspace .
  1. If you have already measured the focal length and material thickness, you can enter the thickness in Printing Auto Mode .
  1. Set a relatively small value (e.g. 1%) for Laser Power and turn on the laser beam.
  1. Use **X- / X+ / Y- / Y+ ** to move the laser dot to where the work origin will be, click Set Work Origin and Run Boundary to check if the work origin is at the right place.
Note : If the work origin is set up incorrectly, please reset the work origin and run boundary again.
  1. Click28.png to start engraving / cutting.
Note 1 : The computer must be connected to the machine via Wi-Fi throughout the process.
Note 2 : You can change the settings for Laser Power and Work Speed during the engraving / cutting process.
Note 3: The Laser module will reach a height of (Material thickness + Laser height).
Note 4: “Z” button on the touchscreen will grey out and the machine will consider the height of (Material thickness + Laser height) as the focal distance.
Tips : If the material thickness is unknown, you can deselect Printing Auto Mode and change to Printing Manual Mode .
When using the Printing Manual Mode , please do the following:
Set a relatively small value (e.g. 1%) for Laser Power and turn on the laser beam → Use X- / X+ / Y- / Y+ / Z- / Z+ to move the laser dot to where the work origin will be → Use Z- / Z+ to adjust the height of the laser module until the laser beam is focused down to the smallest spot → Click Set Work Origin → Click Run Boundary → Click28.png to start engraving / cutting.
Manual-focus
  1. Before you connect your computer to the machine, make sure both the computer and the machine have connected to the same Wi-Fi. Open Snapmaker Luban and go to Workspace 1.png → Connection → Select Wi-Fi → Click1.png → Select your device → Click Open → Tap Yes on the touchscreen.
  1. Go to Workspace 1.png and click Send via Wi-Fi .
  1. After the machine has received the G-code file, tap Yes on the touchscreen to access the preview page for engraving/cutting.
    Note 1 : If you want to learn more about the Auto Mode and Manual Mode before you start engraving / cutting, you can go to section Auto mode and Manual Mode.
    Note 2 : Files sent via Wi-Fi are saved in the FilesLocal on the touchscreen.
Tips:
  • When using the auto-focus, the machine will consider the proper focal distance equals the sum of material thickness and laser height.
  • Laser height is a safety distance of the Laser engraving module, which should be from 21 - 25 millimetres.
HI edwin 've a question. according the quote above. to ajust the z distance do i have to place the material already on the bed, or adjusting z distance after placing the material?
reason i’m not able to cut with the laser in plywood 5 mm.
despite laser power 100% , speed 300 and above ( lower speed gives thick burned lines), also increasing passes from 2 to 10 does not work. z pas 0.6 mm.
with this setting it should cut at lest 5 mm
advise please Harry
@hld You don’t need to ask this on two threads.
Answered on the other.
Thanks i was also afraid that it would not work :+1:
