Just saw the comment from Rainie
"It is used to cool the print. This is the main function of this fan."
If that is the case then I can probably go back to my original design that deflects all the air to the nozzle
with my gate valve you could actually vary how much of the flow goes toward the nozzle and how much vents the other direction. If there is no fan speed control, thatās an alternate option for adjusting it.
gjo,
Could you post the .stl of your original fan shroud with the full redirect? Also, did you notice better print quality?
vuudoopham,
its hard to say - bridging is a bit better. Attached find stl for full defection snapmaker_fan_cover_10mm_v10.stl (128.9 KB)
gjo,
Thanks! I installed some variable speed cooling fans on my enclosure. I can maintain an enclosure temperature of about 3 degrees C above ambient and I noticed a HUGE increase in printing quality. I am hoping to see some additional gains from your shroud. You should put both of these designs on Thingiverse. I think people would love to get their hands on this piece. Thanks again!
~Vu
@vuudoopham what kind of fan did you get for your enclosure? I am thinking of installing one on mine as well. Do you have it blowing in or out of the enclosure? I notice it gets really hot when printing and at some point the filament will buckle in the nozzle and the print will fail. So iām hoping this fan will alleviate this problem.
@gjo thanks for sharing those cooling fan redirects for the module. Iāll try them as well.
I think what I went what I did was a bit over kill, but print quality was vastly improved. I went with these variable speed fans from AC infinity (https://www.amazon.com/gp/product/B009P0R6VC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1). I actually installed a fan for pushing into the case and one to pull from the case. I pulled in from the rear of the case and pushed out the top. I started with just pushing in through the rear, but noticed much better performance with the push/pull setup. I used this to measure temperature inside the case and outside the case. It has two probes. You will need a 5 volt plug though (https://www.amazon.com/gp/product/B06XC9T6HB/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1). At 3/4 speed, I can maintain ~3 degree difference between inside the case and ambient. I am using to reading temps in F, but I have learned to convert things to C.
Note: I used doubled sided tape to secure the fans.
Note: At 3/4 speed the setup is kind of loud, not louder than the printer without the enclosure, but its louder than it was before.
Let me know if you want met to snap a few photos of my setup.
~Vu
@Tone - Did you ever finish development of the nozzle air deflector?
Yes, pretty much. I have it built, just need to test it out.
I think it will work well, just have to verify it.
I have another idea that might just supersede this one, build the ducting into the enclosure and then 3D print the whole housing. At the same time, separate the air flow for the other fan that keeps the input section of the filament cool. Incorporated into that idea I want to make the housing easily removable and separate from the mount that fixes it to the X-axis carriage. That will make a lighter module. It will take some time to develop.
@Tone, Can you share the nozzle air deflector as you have it now? I am more than willing to help test it.
Iāve installed it. Iāll try to get it up on Thingiverse today as is. It does have a slight alignment issue. Itās not quite centered about the nozzle and I had to bias it as I tightened the screws down. A couple other tweeks I want to do but I will get it up shortly.
Itās up now:
So Iāve printed a few parts with it. It seemed to help with one problem part I printed before. Iāve got a bunch of improvements I plan on making. The ābumpā sticks out too much so Iām going to reduce the size. I also want to swing the cooling nozzles around such that there is a better view of the printing nozzle. After studying the internals of the module I plan to add some baffles to the shroud to help segregate the cool air from the warm air. Currently the other fan is blowing over the filament cooling section and any warm air gets fed either into the outlet by the printing nozzle or into the bottom fan. In order to better route the air Iām going to design new end plates that will better route the warm and cool air and separate the module into two different regions, one that is for the filament inlet cooling section and the other one that is for the bottom cooling fan. Itās important to make sure the warm outlet isnāt close to the cool inlet thus feeding warm air in.
If anyone has any other ideas or feedback please send it.
Maybe you could change your design to make use of the Bernoulli suction effect to draw some colder air into the air stream
The opening around the nozzle is letting the exhaust from the big fan to exit right down onto the print area. That area needs to be blocked of with something that can handle the heat.
Wow @Tone that looks awesome. Will have to print a set and give it a go. Thanks for sharing.
Thereās still some improvements I want to make.
If you have any suggestions, requests, let me know.
Currently the left side has hot exiting the top and the right side is opposite.
I may want to make both have the hot exit the top to keep it away from the print.
Currently the slot in the valve doesnāt line up with the flow direction. You actually have to look in the back redirection port to see if the valve is oriented right.
New version uploaded. Better looking, improved nozzle visibility, improved air flow. Now includes a āwedgeā to better block off air from hot side. Be sure to read the āNotesā section.
